Perform this procedure to configure the additional addresses for which the virtual router acts as a back up.
Assign an IPv6 address to the interface.
Enable routing globally.
Do not configure RSMLT on the VLAN.
- To create a secondary virtual IP address on a VLAN:
Create primary and secondary IP addresses on the VLAN.
Create a VRRP instance on the VLAN.
Configure a primary virtual IP.
Change the VRF instance as required to configure additional addresses on the VRRP interface on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
The first virtual IP configured on a VRRP interface is the primary virtual IP. After you create a VRRP interface, you can create secondary virtual IPs. Secondary virtual IP addresses must be in the same subnet as a Secondary IP Interface on the VLAN.
You can also complete this configuration through the navigation path.Procedure
- Select VRRP.
- Select the V3 Interface tab.
- Select an interface.
- Select AssociatedIPAddr.
- Select Insert.
- Type the address.
- Type the prefix length.
- Select Insert.
Address List Field Descriptions
Use the data in the following table to use the Address List tab.
Name | Description |
IpAddr | Specifies an IP address that is associated with a virtual router. The number of rows on this tab equals the number of IP addresses associated (backed up) by the virtual router |
IpAddrPrefixLength | Specifies the length of the prefix in bits. |
